ksg5000 wrote:
You can always have a mechanic look at the rig.  Are you sure about the towing as I doubt an older 30 ft Class C would have much towing capacity - they come out of the RV factory pretty much maxed out on weight (at least mine did).  If you do go forward spend an addition $100 or so and get the rig pressure tested - should identify potential roof/window leaks - something you should consider on any used rig.
I know about compression testing the cylinders but who would pressure test the rig for leaks, I never heard of pressure testing for leaks on an RV who would/could do that ?
As far as the car towing, I don't know for sure its a guess based on the 1st owner using it to travel to Florida every year about 1800 miles each way for several months and the fact it has a Blue Ox Tow Package on it.
Thanks
Bill
