dad4papa2ExplorerApr 22, 20191996 Damon Intruder 460 engine Issue Solved!!Back a few months ago I had started a thread about my Ford 460 Engine would start up and run 2 to 10 minutes and then just die as if the key was shut off. It had turned in to quite a lengthy Thread an...Show More
KrustyNomad IIApr 22, 2019It should be set to 10 degrees BTDC with the SPOUT connector disconnected. You may need a mirror to see the timing marks
Related ContentPotential engine overheatingNear engine overheating gauge1996 Damon Intruder engine temp questionDamon Intruder engine cover lock key1999 Damon Intruder lost all power
