MrWizard
Oct 09, 2019Moderator
That's what we do here, help each other,
I bought the Inova version
It displayed real code numbers on an LCD display and saved them in memory
My problem turned out to be a failing fuel pump in the gas tank
I installed an external full pump in the main fuel line, at the fuel filter on the driver's side of the frame ,, that was in June ,,,
But before I found the problem, I replaced the icm and the fuel pressure regulator !
It took me several months, in many cases the code number has several possible causes, and each one has to be checked and found to not be the reason for the error code,
Once I was convinced it was in fact, the worst possiblity, I had to figure a solution that did not require, having someone drop the gas tank and replace the pump,
