wvhurricane's avatar
wvhurricane
1996 F53 Radiator hose search not going well
Does anyone have ANY part numbers for the upper and lower radiator hoses for the 1996 Ford F53 stripped motorhome chassis? I have come up with zero results in this area (including with the local Ford dealership) Turns out there are major differences between the auto parts stores F53 truck and the F53 motorhome chassis. None of the local dealers list the motorhome version.
Any advice will be greatly appreciated!
  • Thanks RLS7201! I found this on an old threat on irv2. Good stuff
    Posted By: RLS7201 on 11/26/09 11:35am
    DAYCO Part # 5060505 {Exceeds OE Specifications}
    Fan, Alt. & A.P., w/130 Amp Alt.
    GATES Part # K060505 {Automotive V-Ribbed Belt (Standard); K06 13/16" x 51"}
    Fan, Alternator and Air Pump; W/130A. Alt.
    GATES Part # K060685 {Automotive V-Ribbed Belt (Standard); K06 13/16" x 69
    1/8"}
    Fan, Air Conditioning and Power Steering
    ACDELCO Part # 6K685 {K06 13/16" x 69 1/8" #88932724}
    BELT,SERPENTINE FAN, A/C & P/S
    GATES Part # 38140 {Belt Drive Tensioner; Thermoplastic Smooth (90mm x 17mm x
    32mm) - Flanged / Hydraulic-No}
    DAYCO Part # 89221 Belt Tensioner
    ACDELCO Part # 1520676 {replaces 88919204 #19190145, 88919204}
    TENSIONER,DRV BELT TENSIONER PULLEY
    This is the short hose that goes from the oil cooler to the water pump:
    GATES Part # 21909 {Molded Coolant Hose; 1 11/16" x 1 25/32" x 3 19/32" Does
    Not Contain Spring}
    Lower - Pipe To Water Pump
    Motorcraft KM4941 Upper Radiator Hose
    RECREATIONAL - STRIPPED CHASSIS - F53
    Motorcraft KM4969 Lower Radiator Hose
    PCV Valve:
    STANDARD MOTOR PRODUCTS Part # V326
    Thread Type
    The transmission filter you need is for a 4x4 460 W/E4OD, Pick up. Just tell
    them you need the tall filter (deep pan)for a 4x4.
    ACDELCO Part # TF283 {#25174481}
    FILTER KIT,A/TRNS FLUID 20 HOLES, DEEP PAN; E4OD TRANS, 4 SPEED
    The upper and lower radiator hoses are becoming very hard to find. Most listings
    are for the F53 truck and will not fit the F53 motorhome. Different radiator for
    each application. Your friendly Ford truck dealer can supply them for approx.
    $45.00 ea.
    Approx. $25.00 ea. from Motorcraft, through your local parts
    supply house.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Radaitor hoses have two or three IMPORTANT pramaters.
    Length
    Diameter
    Upper or lower (one of those can be used in either place I think Lower).
    Next hoses come in two "Styles" Pre-bent Fixed shape hoses. hard to find for older rides or rides with custom made parts. Flexible Universal. HINT HINT HINT.
  • Thanks for the advice guys. Rock Auto really not much help as they only have a listing for generic F53. Which may or may not fit the motorhome. I did look there and they listed several different upper and lower hoses...all quite different from each other. I ordered the hoses that RLS7201 suggested. Those hose numbers dovetailed nicely into an old thread I found on irv2 and the pics and length look to match what I have. Thanks Again!
  • I only use Gates Rubber Green or White stripe hoses and belts on ALL my vehicles (RV included) and the Gates website will steer you to the correct part numbers.
    I never cheap out on them, a blown hose or failed drive belt can bring an outing to an abrupt end, right now.
    For me, only Gates Fleetrunner products.
  • Chassis are usually a year older than coach when trying to find parts.
  • Motocraft KM4941 Upper Radiator Hose.
    Motocraft KM4969 Lower Radiator Hose.
    Short hose between water pump and oil cooler GATES Part # 21909.
    Richard
  • Did you try RockAuto,com? Look up the F53 and match to yours.
  • Can't you take your old one into an auto parts store? That's how I did it a few years ago for my Cummins diesel engine. Car Quest I think. They took about 5 minutes to match it up with a stock hose.
