RLS7201
May 27, 2019Explorer II
MrWizard wrote:
the fuel filter in mounted on the inside of the drivers side frame rail uses quick connect fittings
i want to add an inline fuel pump at the output side of the filter to boost fuel pressure to the engine EFI system (yes its low)
i don't want to cut any fuel lines
i want to couple the new pump into the system
if i can find a pump with the correct male ends
One piece of new looped fuel hose with female quick connects
will couple it all together
additional wiring from the fuel relay is of needed
I hope you understand the capacity of external pump you need.
The pump should be rated for a minimum of 60 PSI @ 30 gallons per hour.
Richard
38,769 PostsLatest Activity: Mar 31, 2026
