Wild_Bill_888
May 27, 2019Explorer
The fuel system is designed by Engineers who actually know what they’re doing. If your fuel pressure is low after you replace the fuel filter with a new one, there is something else wrong.
It could be a bad fuel pump, a clogged pump inlet filter, a crushed fuel line, or a faulty fuel pressure regulator allowing excessive fuel to flow back to the tank.
You should focus on finding the root cause of the problem before you fix it.
38,769 PostsLatest Activity: Mar 31, 2026
