Yaj
May 08, 2013Explorer
1996 Frieghtliner Transmission 12V power question?
Hello all!
I have a issue that came up about 500 miles from home.
While cruising homeward bound my 3060 transmission started acting up.
First it lost all indicators on the touch pad, the speedometer went dead and it wouldn't shift. It seemed like it was in 5th gear with quite a wide rpm range. Then it cleared up.
Within 50 miles I stopped to dump my tanks, shut down engine. Then I started the engine and right away it did the dead thing again and also showed "do not shift" on the dash. I pulled over out of the way, shut down, and the engine would not start again. It showed the "do not shift" on the dash, and clicked under the dash, but no joy.
I figured since the touch pad was dead that the transmission wasn't telling the engine, hey I'm in neutral so you can start.
I checked the obvious, and after much head scratching, I opened the Allison box with the 6 relays under the dash. It has 2-10 amp fuses in it, one labeled "Main Power" the other not labeled, both fuses good. The main power fuse did not have any power regardless of what I did, But the other fuse would show 12V with the key on. I tried swapping all the relays around and I got nothing. I finally supplied 12V from a different source (with a 10 amp fuse inline) to the fuse labeled Main Power and I have JOY!
We made it all the way home without further incidence, I disconnected the alternate power source whenever we stopped. And I am about to start trouble shooting it.
I think it my be a bad relay under the dash as there are several tucked way up where they can't be seen, only felt by hand. One or more does click when I turn the key on.
I thought before I started trouble shooting I would bounce it off the minds here to see if I'm going in the right direction.
I offer a early thank you for any thoughts you guys might have.
I will check back in about a hour. And I will post to this thread the outcome for all to gain from!
Sincerely,
Jay Herte
Sincerely,
Jay Herte
