southskier's avatar
southskier
1996 Fuel Cut Off Switch
Hi,
I have a Sellers Motor Corp Class A RV that is not starting. It will turn over with the key switch, but will not start. From initial testing, it seems that it is not getting fuel, but I want to make sure that it is not a relay or fuel cutoff switch before looking further in dropping the tank to replace the fuel pump.
It is a Sellers Motor Corp with a Ford RT500 Series Chassis. Could there be a fuse or sending unit that is faulty? Or where would the location of the cutoff switch be?
I appreciate the assistance, just trying to get it running for camping season.
Thanks,
Rob
1 Reply
  • with a vin number and a helpful ford dealer you should be able to get a wiring schematic, the fuel pump circuit should have a relay and also an inertia switch to shut the fuel pump off if you hit something too hard, they sometimes fail without being in an accident.
