- Chum_leeExplorer
larryPonich wrote:
I need to find out which colored wire goes to which terminal on the
5 pin relay as the wires were pulled out.
The relay should have a schematic printed somewhere on it. (shows which wires do what) There should be two larger size wires (current from main bus to fuel pump) and three smaller control/signal wires. If you can find a wiring diagram (factory service manual) it will tell you which color goes to which terminal.
Chum lee - MountainAir05Explorer IIThis is for relay 15528707 go down to reply 18 and see if is the one you have.
https://www.classicwinnebagos.com/forum/index.php?topic=8795.0
38,782 PostsLatest Activity: Sep 10, 2026
