D_E_Bishop
Jun 07, 2017Explorer
The ATS will be between the junction box where the shore cable changes to the coach AC circuit breakers. It is usually in the cabinet near the entry point. If turning the generator circuit breakers on and off doesn't reenergize your system, open the ATS and check and see if there is power on the generator line size. I would normally suggest you open the junction box on the generator but I'm not sure what is available or where it is located. If the generator is not putting out power, it's not the ATS and a qualified shop should be consulted. If the generator is putting out power to the system, it is possibly the ATS.
38,782 PostsLatest Activity: Sep 10, 2026
