huachuco's avatar
huachuco
1997 Country Coach Intrigue
I have recently purchased a 97 CC Intrigue and am about through with a lot of upgrades.
Question: Did CC install a switch for the hot water heater to switch between propane and electric?
Any info is appreciated......thanks and safe travel......Dave
  • polar76 wrote:
    I have a 97 Allure, no switch on my, I just turn the breaker of when I am on 30amp or less.only switch for gas is on my range hood.
    You can run both if you want to heat it up quickly...
    For that year this is a great solution. For some odd reason many did not come with switches... Never figured out that one!
  • dons2346 wrote:
    Hot water heater...Why are you guys heating hot water?
    When you could be using it to unthaw the freezer irregardless
  • Hot water heater...Why are you guys heating hot water?
  • On my 96 Vogue, the switch is the breaker for the electric portion, otherwise there is a switch for gas. I always use it on electric(30 or 50 amp).
  • I have never used mine on electric. Looking at it I think the switch on my hwh might be for the electronic ignition. I will have to look at this when I dewinterize and fill hwh with water
  • I have a 97 Allure, no switch on my, I just turn the breaker of when I am on 30amp or less.only switch for gas is on my range hood.
  • I have a on/off switch for the electric right on the side of my hwh. my hwh has access by opening the sink base door. There is also a breaker In the electric panel. For propane I have a switch in the kitchen area.
