John&Joey wrote:
I know you feel like an engine with only 11k on the block after 20 years is a real find, but honestly it might not be.
Oil is only one small item. Hopefully the engine was ran at the most ideal times so that the oil kept internal rust buildup in check. For example if he put on 11k the first year then sat in a barn for 19 years you'll have problems. On the other hand if he did a 100 mile run every few months for 20 years then you got a winner.
Also oil is one of the smallest of things in my mind right now. With so few miles I'm guessing maintenance fell to the wayside. Thinking you got original antifreeze, fuel filter, brake fluid, and transmission fluid all in there from 1997.
I would run that unit very lightly in the beginning and keep a sharp eye out for puddles. Guessing that tranny could be a leaker, and maybe those brakes will lock up after some hard stopping/miles. You might have a great rig there, but I would baby it in the very beginning till the cobwebs are out of it.
Actually, the engine looks brand new. The oil came out looking like it was just changed too. The trans, everything looks brand new. I don't know how often they drove it but it didn't sit for a long period of time, and you can definitely tell they took care of it. It had brand new tires, roof, etc. I drove it home and it did 70mph easily, and now I have the Banks headers on it and it's a real difference. I don't beat on any of my stuff. Everything I have is babied for the most part. I do notice the thermostat seems to be a little sticky.. sometimes the temp will go up near the end of the normal range, and then drop back down to the middle. I just bought a new thermostat for it, but I bought the 160. I know it came with a 192 from the factory so I am thinking about going with a 180 instead. I am going to flush the coolant too, but the coolant looks good. The pan on the transmission looks like there isn't a leak anywhere, but I would like to do that too. Someone has changed the fluid on the rear diff too as I can see a little silicone on it, and it looks like it leaked a little at some point as the bottom is a little soiled.
