enblethen
Jan 31, 2015Nomad
Locate the starter relay. It is normally located on the fire wall under the hood. Follow chassis battery cable to it.
Try jumping the two large posts. The starter should engage.
You could have a problem with a neutral safety switch. By jumping the large posts, you will be by passing the safety switch.
Try also moving the gear shift lever. Try starting in neutral, and then wiggle the gear shift.
