OnaQuest
Jan 31, 2015Explorer
enblethen wrote:You are giving out bad info here. The '97 (actually the '97 BCC) will prevent the rig from starting if the chassis battery switch is OFF. That (switch override) feature was not added until much later on CB-115 rev. D. Once started, however, the chassis disconnect will NOT turn the batteries off - This prevents the accidental loss of power while underway, in the event someone accidentally turned the switch OFF.
If the chassis battery goes into the battery control center, try cycling the battery disconnect switch.
The rig is suppose to be able to run with the battery disconnect in the off postion. Double check for another cable off chassis battery.
