Cikan_Vuz
Jan 31, 2015Explorer
enblethen wrote:
Not sure what version, but my Fleetwood is wired so that the chassis can be started and run with battery disconnect off. The chassis battery goes directly to the starter with a second lead going to the battery control center. Yes, there is certain chassis functions that do not operate with the battery disconnect in the off position.
Mine is on a Chev chassis.
oK, TY All I could find regarding this one is it was manufactured by ford in 10/96 and manu from fleetwood in 12/96 and then in the back closest there is a Serial # B/S -46336
I found the red lead to the starter but lose it up in the firewall behind some very large cylinder thing. I will put some tarp down and crawl under it tomorrow.
Thank you ALL for all your help so far.
