OnaQuest
Feb 01, 2015Explorer
Johno02 wrote:
I'm glad someone else has seen the corrosion thing. up to a point, everything else seems normal, voltages, meters, lights, just not enough wire available for the starter power.
I agree, the problem can be one of many problems with getting current to the starter, however, the symptom that points to the starter relay is "the single click".
Usually, when the problem is low voltage or weak connection, the starter will chatter or otherwise indicate that it is trying. The most notable symptom would be dimming of lights under excessive current when trying to start if voltage is getting past the relay.
Guessing time is over I think. It's time to check the connections and possibly get busy with a meter.
38,782 PostsLatest Activity: Sep 02, 2026
