OnaQuest
Feb 01, 2015Explorer
Cikan Vuz wrote:
what confused me is the click comes from the dashboard, driver area, not from the passenger side, where the starter supposedly is. and it actually only clicks when I flip on the battery button, the other thin is not really a click but just the normal noise the key makes in the ignition when you turn the key on, then there is some noise as the dash-lights light up, but that is it.
Thank you
That certainly changes things a bit.
The click you hear, initially, is the battery disconnect closing to connect the chassis battery. That's normal.
You may have a problem that is actually prior to any start circuits.
After you hear the initial click (batteries activated) can you get the jacks panel to light up? (parking brake must be ON and TX in Park or Neutral). Is the LP detector ON? These are items that would indicate if the disconnect solenoid is actually closing the contacts and not just making a clicking noise without actually working.
38,782 PostsLatest Activity: Sep 02, 2026
