Cikan_Vuz
Feb 01, 2015Explorer
OnaQuest wrote:Lt46 wrote:
Re. the fuel cut-off switch; it will be found low on the firewall, inside and behind your brake pedal. If the switch has been activated a red pop-up button will be visible. Pushing the button down resets it.
The fuel cutoff switch will NOT stop the starter from attempting to crank the engine, it simply interrupts the power to the electric fuel pump. That is not your problem.
ok, I was not sure if if shout off the ability for the vehicle to start, like I used to have a 90's ford ranger and it has a reset switch that kicked in if you were in an accident, preventing the vehicle from starting until a "qualified" mechanic looked it over...
38,782 PostsLatest Activity: Sep 02, 2026
