Cikan_Vuz
Feb 01, 2015Explorer
enblethen wrote:
Did you find the starter relay that RLS7201 posted? The two large posts could be jumpered with heavy wire this should energize starter. This relay is activated by the ignition switch in the start position. This could be the click you hear as it is right next to the gas pedal inside the doghouse.
yes, i found it, and I tapped it with a mallet... nothing happened...
I do not have a voltmeter nor know how to use one though. I suppose it is not difficult to do though, I should get to harbor freight and purchase one.
38,782 PostsLatest Activity: Sep 02, 2026
