Cikan_Vuz
Feb 01, 2015Explorer
enblethen wrote:
Get a 12 volt test light. It is easy to use to many trouble shooting procedures.
Did you tap it with the ignition switch held in the start position?
Do you have a heavy piece of insulated wire about six inches long? If you hold one stripped end to the post where on the photo has the rubber cap to the bare large post the starter should engage.
no, I did not tap it with the key in the start position, I cant hold the key in that position and tap on the relay at the same time ( not that limber it seems...
I have some very heavy gauge wire somewhere from my sons old stereo setup when he was into having the superloud noise aka music coming from his car LOL But, WHAT does the starter even look like and when you say "If you hold one stripped end to the post where on the photo has the rubber cap to the bare large post the starter should engage" I do this with the key in the "on" position, correct?
38,782 PostsLatest Activity: Sep 02, 2026
