zert800's avatar
zert800
1997 Pinnacle manual
We just purchased a 34' 1997 Pinnacle A class motorhome with a few little issues. I was wondering if anyone knew where I could download the manuals for it. This is our 4th MH and the previous three all had manuals, I'm a manual kind of guy. There seems to be an issue with the power step, I'm going to start with the fuses but would still like to find manuals. Thanks
Darryn
  • Pretty much your very best manual is just putting in a search here on RV.Net for whatever product you have. Owners manuals tell you what is supposed to happen, RV.net tells you how to fix it when it doesn't happen.
    I just did a search for Kwikee, and in the last 12 months it came up 208 times.
  • If you have Kwikee steps they need to be lubed to work completely. The motor cuts out at the end of the free running. Motors are usually power window motors from some Ford product. When working on the steps be very careful. Count fingers before and after. When that motor starts there is enough torque to remove a finger or two. Ground is another potential problem because it gets splashed underneath the coach and rusts.
  • Try here for most if you have the model numbers of the components
    http://bryantrv.com/docs.html
  • We had a '99 Pinnacle (just sold it). As you now know there is no source of an 'owners" manual. But you can get and download manuals for most of the appliances from each manufacturer's web site ( google is your friend!).
    Good luck with your 'new' rig. ENJOY
