F4Jock
May 18, 2018Explorer
dougrainer wrote:
The Wiper control on a FORD chassis is a FORD system. That said, the Wiper MOTOR and ARMS/Blades are after market installed by the OEM's. The Wiper module on a Ford is behind the Brake pedal mounted on the Firewall about 1 inch up from the floor inside the RV. I would suspect the Control module. IT sends the pulse signal and is the timer to the wiper motor. Doug
Okay. So you are saying that this module on the inside firewall is the thing that is the problem then, correct?
