dougrainer
May 19, 2018Nomad
F4Jock wrote:dougrainer wrote:
The Wiper control on a FORD chassis is a FORD system. That said, the Wiper MOTOR and ARMS/Blades are after market installed by the OEM's. The Wiper module on a Ford is behind the Brake pedal mounted on the Firewall about 1 inch up from the floor inside the RV. I would suspect the Control module. IT sends the pulse signal and is the timer to the wiper motor. Doug
Okay. So you are saying that this module on the inside firewall is the thing that is the problem then, correct?
I would swap out the Ford module as a first. There is no way to test the Ford Module. It is either the Ford Module or the Wiper Motor and the motor will be a challenge to find. You will have to get the numbers off the motor and then do an Internet check. Doug
