F4Jock
May 24, 2018Explorer
dougrainer wrote:
The Wiper control on a FORD chassis is a FORD system. That said, the Wiper MOTOR and ARMS/Blades are after market installed by the OEM's. The Wiper module on a Ford is behind the Brake pedal mounted on the Firewall about 1 inch up from the floor inside the RV. I would suspect the Control module. IT sends the pulse signal and is the timer to the wiper motor. Doug
Doug, I would like to thank you very much! This was indeed the problem. After locating the module and finding out that Ford wanted 350 bucks for it I found one at a local junkyard for $35, installed it and that was the problem! Once again, thank you!
