dougrainer
Jan 21, 2018Nomad
The Magnet works off a Ground(negative) feed. When you open and close the door, the step light should come ON when the door is opened and go OFF when it closes. The White and RED wire at the 4 wire quick connect should have 12 volts when the manual step on and off switch is ON on your year model. From your description the problem is the 2 wires going from the magnetic switch. Doug
38,782 PostsLatest Activity: Sep 10, 2026
