Fulltimers
Jan 21, 2018Explorer
If you hear the control module under the step click when you open and close the door then the motor/gear box is jammed up. You can remove the assembly and take it apart, clean, lube, and reassemble. Mine did this twice.
38,782 PostsLatest Activity: Sep 10, 2026
