beavercommander's avatar
Jul 26, 2013
1998 Beaver Patriot Thunder water heater switch
STILL HAVING TROUBLE LOCATING THE WATER HEATER SWITCH****This coach has a Seaward water heater, runs on electric. The heating system is a Hurricane and we have looked every where for the water heater switch. All we can find are Hurricane switches. There is a switch on the dash that says pre-heat but we think that might be for the diesel. We did not get much info when we bought this last Aug. So I am depending on those of you with the experience! Thanks for your help in advance. Donna
  • Most in that time frame Beaver/Safari had a switch in the compartment outside with the water heater. Upper left corner if memory serves on our '99.
  • My suggestion......locate wires on electric element and then trace them back to ON/OFF switch.
    As for the LP side........are you sure it operates on propane?
    Thought Seaward were electric and engine heat exchanger.
    Seaward
    Products
    3721 Capitol Avenue
    Whittier, CA 90601-1732
    Tel. (562) 699-7997 Fax. (562) 699-0908
  • Mine only runs on electric and there is no switch only the breaker in the closet.
  • Try to take a look under the kitchen sink compartment. Many times they used to connect that switch down there loose on two wires.
