LonestarV's avatar
LonestarV
1998 Fleetwood Bounder dash air not working
I have a 1998 Fleetwood Bounder Class A. 34 footer on the F53 chassis with Ford V-10.
I've owned the RV for a few years now and the dash air hasn't worked in that time. Time to tinker just wasn't there, and RV service shops weren't too excited to get involved in it.
Well the time has now come and I'd like to see what I can do to get it working.
Pushing the A/C light on the panel does nothing (it looks like a little light is supposed to illuminate, but does not). Certainly no cold air, not even "seeping" out.
Clicking up the fan speed does nothing as well. The only thing I've accomplished to this point is locating the 3 relays behind the passenger kick panel and replacing those. Now when I change fan speeds the relays click.
What next?
Any pointers are greatly appreciated.. this is one system I really don't know much about.
  • Your dash air system is just like a car. Is there an automotive AC service place near you? I would think TX is the best state to look for something like that. If the blower won't work that would be a good starting point. Check for blown fuses. Once you get the blowers runnng you then need the compressor working. If it has sat that long with no use the seals are probably dried out and you need some work on the copressor. This is a good time to convert to 134A refrigerant.
