Mr_Mark1
Jun 24, 2014Explorer
jlud, as you probably know, you will need to check date codes on the tires. That coach has obviously sat for a long time with only 40K miles and only 70 hrs. on the genny.
I'm not a mechanic but what I have gotten from this site over the years as a low used unit will hit you in the wallet big time. I'm assuming it does not have slides which is proably a plus in this situation.
Consider that if the unit looks good, you might have to 'zero' out the coach. Tranny fluid change, air dryer inspection, brake inspection, generator oil/filter change, etc. Coaches don't like to sit, just keep that in mind.
Let us know how it all works out and the best of luck to you!
MM.
MM.
38,778 PostsLatest Activity: Jun 07, 2026
