udidwht
Mar 27, 2022Explorer
I bought a 94 Southwind Storm back in Sept 2014 with just shy of 45K on the OD. It is now at 71K. But I do nearly (90 percent) all my own work and have replaced a lot that I consider aging out (sensors, hoses, belts etc...) also put in a new fridge.
Picked it up for 8K and I've likely spent another 4-5K just in replacing items I know that are old (working though) rather than risk it being an issue on a trip. It is a P32 chassis with TBI 454 w/4L80E trans. And thank god this RV has no Auto park brake system.
Items I've replaced (Delco parts only if avail.)
1. TPS
2. EGR
3. VSS sensors
4. Purge valve
5. PCV valve
6. Idle control solenoid actuator
7. MAP sensor
8. O2 sensor (only 1 single wire)
9. IAC
10. Alternator
11. Belts
12. Radiator hoses & by-pass hose
13. T-stat
14. Ignition coil
15. Ceramic wired HD
16. Plugs
17. Distributor pick up coil
18. ICM
19. Aux fan motor
20. Front tires
21. Ignition switch (steering column)
22. Front rotors & pads (Centric ceramic)
23. Master cylinder
24. Doghouse relay
25. Rotor & cap
26. Shift solenoid A&B and internal wire harness (4L80E)
27. New batteries (x3)
28. B.I.R.D/Isolator relay/Solenoid
29. New fridge
30. LP regulator
31. Restored exterior of LP tank
32. DRAC module
33. Drive shaft rebuilt
34. Rear diff fluid
35. Trans fluid DexVI (x2 so far)
36. Exhaust donuts (x2) and springs/bolts
37. Generator VR regulator, fuel line, filter (Onan Micro4K)
38. Toilet
39. Shower faucet valve
and I'm sure some other stuff...LOL!
1. TPS
2. EGR
3. VSS sensors
4. Purge valve
5. PCV valve
7. MAP sensor
9. IAC
10. Alternator
11. Belts
13. T-stat
14. Ignition coil
16. Plugs
18. ICM
19. Aux fan motor
20. Front tires
23. Master cylinder
24. Doghouse relay
25. Rotor & cap
29. New fridge
30. LP regulator
32. DRAC module
34. Rear diff fluid
38. Toilet
38,782 PostsLatest Activity: Sep 10, 2026
