mgrovesjai
Feb 03, 2014Explorer
I got quotes from several including Beaver Coach Sales - $1200 to do exterior seals on 1 slide (I suppose that includes materials). They stated there are exterior and interior seals (interior seals would involve removing the cabinets and an additional $650 for that labor I think).
I've also gotten responses from Coach Masters and the seal material runs from $145 to $175 but the labor hours could run up to 17 depending. Coach Masters wrote of inner seals as well, and removing cabinets 6-7 hours.
I am really not sure what either company means by "interior seals", other than the seals which run around the opening, but they seem to be the only seals in the system. They are stationary and I don't think the inner fiberglass flanges (covered with wood on the interior side) have any additional seals. I will have to examine the unit more closely to see if there are seals on that side - easy to see with the slide in the coach but I haven't looked.
I do know there are no seals outboard, rather just sealant (I think some owners refer to it as "butyl". And that is the "seal" that presses against the non-moving seal I described earlier when the slide is in, so again, I don't know of an inner seal. Perhaps the butyl should be redone but I am not sure. I guess its condition (suppleness) can be evaluated.
I still haven't talked to Jim Cooley directly but hope to today. OMC has been around, I think, since 2008, so I am not sure how many Beavers they have seen. They are closer for me than Bend, however, a haven't made quite the job of it as those in Bend have, however, I will assume the Bend companies have worked on more Beavers.
A little off-topic, but I also like that OMC stocks the Peak Final Charge anti-freeze which I want to have installed, at $14.99 for the 100% gallons of anti-freeze.
