navegator
Mar 12, 2015Explorer
If you can see the color of the wires at the plugs, you are looking for these colors.
Green
Yellow
Brown
Red
White
Blue
Green is right brake/turn signal
yellow is left brake/turn signal
Brown are the running lights
Red is positive +12 Vdc
white is ground or negative -12 Vdc
Blue is where the signal from the brake controller is transmitted from the controller to the trailer
Look for those colors, if you have a tester, turn the flashers on and check the plugs, if I an not wrong there should be a trailer brake controller somewhere on the dash board, unless it has the built in controller.
navegator
Green
Yellow
Brown
Red
White
Blue
navegator
38,778 PostsLatest Activity: Jun 10, 2026
