tatest
Mar 12, 2015Explorer II
Before testing the circuits, you may have to install the fuse for the brake controller supply line. There could be a dummy fuse in that slot.
Similarly for the 12V charge line, if the RV manufacturer did not run that line out to the 7-pin socket. Wiring is sometimes incomplete to that socket as use of some pins are slightly different when towing a vehicle vs towing a trailer.
38,778 PostsLatest Activity: Jun 10, 2026
