j-d
Mar 13, 2015Explorer II
If Bryan told you "Brown" it's Brown. He has that van and tows a trailer with it. Use one of these
with the clip on a known good ground. I wouldn't think the key even has to be ON for a brake pedal push to light the tester's handle when you touch the pin that went hot. Unless you blew a fuse like I did. Nice PIX of those fuses. Can you give us shots of the labeling that shows which fuse serves which circuit?
with the clip on a known good ground. I wouldn't think the key even has to be ON for a brake pedal push to light the tester's handle when you touch the pin that went hot. Unless you blew a fuse like I did. Nice PIX of those fuses. Can you give us shots of the labeling that shows which fuse serves which circuit?About Motorhome Group
38,778 PostsLatest Activity: Jun 10, 2026
