wolfe10
Apr 21, 2019Explorer
Check voltage to the small signal terminal (s). If 12+ VDC, the relay is bad. If one small signal terminal it will be the positive (with ground through the relay's body). If two, one will be the positive, one the ground/negative.
You can also use a small jumper wire from the 12+VDC lug to the POSITIVE signal terminal after removing the wire to the positive signal terminal so you don't back-feed that circuit.
