- crassterExplorer III like Kirkland signature from costco.
- cbeierlExplorer
cbeierl wrote:
The Built on Freightliner info for your coach calls for Two 760 CCA @ 0oF (-18oC); maintenance-free (group 31) batteries for the chassis. More CCA would be even better.
Looks like I included to link for the 2007 Discovery by mistake. Here's the correct 2008 Discovery Built on Freightliner info. The battery info above is correct. - dropalineExplorertry battery plus best, price and they installed house the batterys also
- krivanjExplorerDeca are good batteries too. Made in USA. I have had good luck with them over the years.
- IvylogExplorer IIIHad a hard time deciding to go back with Interstates that only lasted ten years.:B I actually put them in a 24V machine to see how much longer they will last.
Even main free have caps that will let you add a little water every two years. - RollnhomeExplorerI found my best deal at Freightliner shop, forget what I paid, price was right. I got 2 group 31 950 CCA maintenance free batteries for my 08 Discovery. I went maintenance free because of the crappy access.
- cbeierlExplorerThe Built on Freightliner info for your coach calls for Two 760 CCA @ 0oF (-18oC); maintenance-free (group 31) batteries for the chassis. More CCA would be even better.
- What_s_Next_ExplorerThese are the engine battery's that i need to replace.
- hersheyExplorerI replaced my engine batteries with Interstate.
I replaced my coach batteries with Costco 6 volts. I'm happy with the results with both. - Big_KatunaExplorer IIDo you belong to a buying club? Hard to beat Sams or Costco.
I would add a Profill System while your at it.
