Golden_HVAC
Jul 23, 2014Explorer
I agree that you need a more reasonable mechanic.
Try a local RV repair place, or truck repair place. They should be able to get the fan shroud off, then the fan blade, then the clutch. Water pump at the same time will probably only add a few dollars to the project, however if you need to change the water pump in 2 years, the whole process of removing the clutch is repeated, then about 8 more bolts to remove the water pump, then re-assemble everything again.
Might even call a Ford dealer. They can beat a $1,000 price estimate.
Fred.
Fred.
38,768 PostsLatest Activity: Nov 21, 2015
