tropical36
Nov 06, 2018Explorer II
glamisorbust wrote:
I called allison today, and this transmission (MD3060) doesn't have a neutral safety switch on it. I did get it started and moved today but not with the key. I used a push button switch right to the starter.
I'm going to run a new wire from the ignition switch to the start solenoid and see if I have a bad piece of wire somewhere. Allison also told me there is a black box "under the dash somewhere". I took the dash apart and couldn't find it.
But supposedly this box is black, 4 1/2" x 4 1/2" x 2" and contains 6 relays and 4 fuses. They say a fuse or relay gone bad here will cause my problem. Gonna keep looking. Thanks for all the help.
Just wondering if you read my last post and most sure you have a aux. solenoid prior to the main starter solenoid and the usual culprit.
I would caution you about running a wire directly, without knowing the current draw and specs of the ignition sw. itself. All the fuses, relays and solenoids are in there for a reason and the control circuits that feed these items aren't meant to carry the full load.
38,782 PostsLatest Activity: Sep 10, 2026
