MinnieBull's avatar
MinnieBull
1999 Minnie Winnie: is the roof and cabover one piece?
Hi All, I’m in the process of trying to restore a 1999 Minnie Winnie that’s in need of a complete cabover rebuild, new roof and side wall delamination fix. I was prepping the roof expecting to see a seem where to roof meets the top of the cabover but there is none. The filon seems to keep going and wrap around the cab. Is the filon roof and cabover “wrap” one piece? Thanks for any help you can lend.
  • The seam should be right where the box meets the cab-over portion. There is usually on those units a forward slant where the box roof meets the cab-over roof with that transition point the seam. Unless someone worked on the roof and did their own thing, the roof transition strip between the box and cab-over should be there.
  • Howdy, my 02 Winnebago 24v has a fiberglass roof similiar in appearance to the wall material just white. But I have a seam right above where the cab meets the box. I covered it with Eternabond. I bet you have a seem there also but just a very easy transition.
