pcook wrote:
Through my research, the Winnie 26a doesn't have automatic levelers which to me is important as my wife and I get older. Would there be manual levelers instead? If not, how would one tackle leveling this type of unit?
If I didn't already have levelers I'm not too sure I would add them due to the expense. Until 2018 I used 2x8 planks and a 4x4 to make ramps.
When I first purchased my rv I found a level parking lot and used a bubble level inside the freezer to level the rv. Once I did that and while it sat level I installed 2 small levels inside the cab that I could see from the drivers seat whenever I park.
One is on the dash and one is above the passenger door. Most of time, all I have to do is move around the site a little bit to find that level spot with no need to use any leveling.
I have auto levelers on my new rig and sometimes also use wood blocks that I always carry to use as ground pads under my levelers because they offer a larger footprint which helps on soft ground.
I find it easier to use them in the manual mode so I can
lift each corner or NOT lift a particular corner. Leveling in the AUTO mode usually lifts all 4 corners and then levels it. That can be too high at times and makes the first step into the rv a high step up.
So I don't have to crawl under the rv, I drilled a hole in the corner of each wood block and attached a length of rope so it's easier to pull them out when departing a campsite.
My levelers were installed too low to the ground and the feet scraped on driveway aprons. I had to have them cut and placed higher into the frame for ground clearance.
