oldave
Nov 05, 2019Explorer
Robbie Welch wrote:
Oldave rereading your reply the vacuum generator may be what I was looking at. I did find a bad connection on it but I never fired up the coach after nothing ran after I repaired the connection. I'll put it back together and run the coach to see if its repaired. I'll let you know how it goes. Thanks
Right Robbie you'll need to run the engine because the vacuum gen
uses air pressure .
Finding the bad connection will probably fix your problem .
Good going .
Ray
