Robbie_WelchExplorerNov 04, 20191999 Monaco Windsor Dash air/heat troubleMy 99 Windsor only blows thru the defrost vents. I know this is the default function because of no vacuum. My question is where does it get its vacuum from? I though there would be a 12volt vacuum pum...Show More
ferndaleflyerExplorer IIINov 06, 2019That was good. So many things on these motor homes are simple to fix if only we could find what is causing the problem---
Related ContentDominic air/heatingany one having trouble with their lance camper roof ?Heat pump blowing cold airMini Split Air Conditioner / Heat pumpTrouble with California
