darsben
May 28, 2014Explorer II
YOur solenoid is under the hood on the drivers side of the vehicle in the black box that has the breakers and fuses in it. Take the cover completely off to see the solenoids.
TAP the main solenoid while someone pushes on the switch. That should get you started. If it does you can buy a new switch on the internet.
I have exactly the same class A
38,766 PostsLatest Activity: Jan 10, 2026
