MountainAir05
May 27, 2014Explorer II
I turn them off when I don't use. They are sucking the juice out of the battery. Keep it simple when you are checking things out. No 12 volts to the ref. means it will not light. Someone should jump in who has your model. Before you try to light the refrigerator light the cook top so you can get the air out of the system. Ensure that you have 12 volts to the ref. Can be check on the outside panel. Welcome to the forum. After you get everything reset and check post back.
