jhilley wrote:
The mobile technician may have been the most expediant solution. Most are very good. If they couldn't get you going, they would have then towed you to a repair facility. Sounds like the tow truck operator may have found what was leaking in order to unlock the brakes to tow.
I considered having a mobile tech come out to try and fix it, but I was concerned that he might not have the necessary parts available, and then the motorhome would need to be towed anyway.
With Coach-Net, it is the customers choice to decide if a mobile tech could solve the problem, or call a tow truck. They will not pay for both services if the mobile tech can't fix it. Since I didn't know the extent of the air leaks, I chose the tow truck.
Also, the turbo outlet pipe had broken loose. I described that problem in another post.
