topflite51ExplorerMar 19, 2014200 lbs psiA good friend claims that he can inflate 16" truck tires to 200 psi without any damage to rim or tire. This is what gets discussed when there is nothing else to do. Any resident genius's care to comme...Show More
Dale_TravelingExplorer IIMar 20, 2014I'm wondering which would go first. The compressor he jury rigged by bypass the safety valve to get that much pressure, the air hose or the tire.I'm sure it can be done but why? If you need to air up that much to carry a given load the axles will snap.
Related ContentMontana Route 200SRoadTrek 200PSItire psiCan I leave a 200 watt Renogy suitcase charger hooked up 24/7
