Romer1
May 20, 2014Explorer
Bruce Brown wrote:Romer1 wrote:
Thanks all for the responses.
Here's the coach:
32V Adventurer
It looks to be in great shape. I did see a couple of things you might want to take a closer look at. It may very well be just how it looks in the pictures, but up front there was a mark, and around the skylight looked a little suspect. On the '01 in the earlier pictures it also had a leak in the skylight, so it's something to be aware of.
Up front...
Around the skylight...
Thanks, will check that out, but I called them to make sure it still available and the salesman said he would check out unit and call back. Said no signs of water inside anyplace, some signs of delam on cargo door (not up on the wall itself)on pass. side, some cracking of decals on exterior. Would rate it a 7-7.5 out of 10.
38,778 PostsLatest Activity: Jun 10, 2026
