rowekmr
Nov 01, 2017Explorer
I watched some YouTube videos and was able to disconnect the plastic fittings so I could remove the reverse osmosis system.
But I forgot to ask 1 more question. I found the chassis battery disconnect switch in the rear compartment that I plan to use coupled with the house battery disconnect on the electrical panel inside but reading the owner manual it says the propane gas detector will still stay on. Any way to cut it off so won't drain batteries dead?
