BTPO1
Mar 05, 2014Explorer
If everything else is working on 120 OK, then I would think that there is a problem with the wire going to that receptacle. May be a loose connection, or a broken wire on the receptacle . You will need to find the source and check it there. May be the neutral wire at the bus bar going to that receptacle is loose or broken. JMO
38,776 PostsLatest Activity: May 15, 2026
