- Peter_CrowlExplorer
RLS7201 wrote:
dougrainer wrote:
RLS7201 wrote:
As already noted, compressor, condenser & receiver dryer are supplied by Ford. The rest of your Fleetwood Bounder F53 HVAC system is supplied by Denso, not Evans-Tempcon
Richard
I disagree:) The OP has a 21 year old Fleetwood Gas. While Denso did supply some Dash AC components to Fleetwood DIESEL models about 22 years ago, they did not supply GAS system components in 2000. Read what Denso has on their website for RV systems. 15 years puts us back to 2005, not to 2000. Also, there should be some tags on the evap cover and area of the OP's stating the maker of his system. He can also go to both Denso and Evans and look at the listing for DASH controls and see which matches his, which will be the maker of his Dash AC system. Doug
HVAC Systems
With over 15 years of providing quality HVAC systems to all the major manufacturers of recreational vehicles, only DENSO has the innovation, expertise and strict quality control to produce the best dash HVAC systems on the market. The DENSO RV HVAC system is a fully integrated system for RV heating, ventilation and air conditioning, engineered to tackle the specific requirements for today's varied motor homes.
Disagree all you want but Denso did supply HVAC to the OP's coach.
My 1995 Bounder gas has a Denso HVAC system. Denso was the premier supplier of HVAC to Fleetwood back then. It's easy enough to tell to tell if a Denso HVAC is installed. It's all electric with no vacuum controls.
Richard
Guys...I found it yesterday as I mentioned above. Just searched the F53 chassis on Rock Auto and there it was. Just over $10 at that! - RLS7201Explorer II
dougrainer wrote:
Richard
HVAC Systems
Richard
HVAC Systems
With over 15 years of providing quality HVAC systems to all the major manufacturers of recreational vehicles, only DENSO has the innovation, expertise and strict quality control to produce the best dash HVAC systems on the market. The DENSO RV HVAC system is a fully integrated system for RV heating, ventilation and air conditioning, engineered to tackle the specific requirements for today's varied motor homes.Krusty wrote:
MrWizard wrote:
Isn't the dash air In class A's add on equipment
And Not from the chassis Mfg
Do they use the stock Ford compressor and dryer ?
I thought everything except maybe the compressor. Is add on from the rv builder not from chassis mfg
The compressor and condenser are part of the Ford chassis. The dryer is attached to the condenser too. The body builder supplies the evaporator housing.
The OP has a 2000 Ford chassis. back then Ford supplied the Compressor and the Condenser. "Usually", the RV OEM builder installed the Dryer and the hoses to the Evap housing and the AC controls and wire harness. And this was more common Evans-Tempcon AC systems. Doug
https://comfortairgr.com/product-category/evans-tempcon-motorome-rv-parts/- KrustyNomad II
The compressor and condenser are part of the Ford chassis. The dryer is attached to the condenser too. The body builder supplies the evaporator housing. - Peter_CrowlExplorer
Krusty wrote:
Look up parts for an F53 motorhome chassis. Dryer is completely different than an F550, which is a truck.
Yes - thanks for the reply. F53 is the key bit. Rock auto has the part and I found it once I searched F53 not F550. What confused me is the F550 documentation that came with the RV. - Peter_CrowlExplorer
theoldwizard1 wrote:
I think it is an F53 chassis.
Yes! And that was the key to finding the part. Thanks! - MrWizardModeratorIsn't the dash air In class A's add on equipment
I thought everything except maybe the compressor. Is add on from the rv builder not from chassis mfg - OOPs! Operator error!
38,773 PostsLatest Activity: Apr 25, 2026
